Toner not Recognized
  • MacTavishLK
    • Nov 2020
    • 70
    Hello guys,
    Model - Toshiba 256SE
    MFP is working properly but Toner not recognized.
    I checked Key Backup and Restore
    I saw,
    SRAM key - KeyBroken
    FROM key - KeyNull
    SRAM license - OK
    FROM license - OK
    SRAM ADIkey - OK
    FROM ADIkey - OK
    I cannot copy SRAM to FROM or FROM to SRAM. Operation Failed.
    Please help me to fix that problem.
    Thank you,
    Have a Nice Day.
    • 8277
    Re: Toner not Recognized
    Are you using Toshiba original toner?
    If yes, make sure the four contacts at the back of the toner cartridge are clean.
    If you remove the copier's inner deck, you can see the four springs at the back that connect with the toner cartridge. Make sure they are clean and not deformed.
    If still not working, replace this same contact unit.
    • MacTavishLK
      • Nov 2020
      • 70
      Yes bro. I am using original toner and I cleaned it. But problem is not solved. Please help me.
      • Drivee
        • Nov 2020
        • 322
        Replace toner...
