Does anyone know the p/n for the gear in dv front section turns the mag rollers and gets drive from the gear that sets on the front plate that has a bearing. And where is all that developer coming from?
I'm guessing your dev unit has to be near or over 1M devs. Those dev units self destruct around 1M, and the rebuild is more expensive than a new unit assembly. To rebuild, you'll need all new seals and bushings, a couple of shfts, and mag rollers. Definitely not worth the time and expense.
Yep I sort of feel the same thing about this dv unit Thanks for the help.
Ive got a p/manual now thru the manual download service offered here at Copytecnet and solved my p/n needs. May The good Lord Bless You anyway in the name of Jesus.
