es355c flashing blue dots
  • irtek
    • Jun 2009
    • 110
    Got a 3555c from wholesaler and when it boots I get splash screen and the it goes these blue rotating dots. I tried reloading firmware but still the same. I have attached a pic. It rotates across the screen. Has anyone seen this before? Thanks for any help on this.
  • irtek
    • Jun 2009
    • 110
    Went past dots on screen and now has large ? on screen
    • irtek
      • Jun 2009
      • 110
      Little more working with it I discovered it is not set for copy screen as default. I know I have changed it before on this model but I am having trouble finding where to change it now. Can anyone help with this?
        • 8144
        Likely where the copier came from, Papercut was installed. You are better off to format the HDD and reload the firmware and start fresh.
          • 22997
          I 100% agree. This machine had Papercut at some point.
          • irtek
            • Jun 2009
            • 110
            I got it figured out. I had already formatted the drive and reloaded firmware but it did not fix it. Found 08-9132 was set to 99 for EWB. Set it to 0 for Copy as default screen. Thanks for the suggestions.
            • djbass
              • May 2008
              • 159
              yes, this can either be set by the 08code or via TopAccess under General settings
              No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
