Counter's Toshiba E45 not change
  • quocanh83
    • Sep 2025
    I have Toshiba E45 when i copier a paper the counter does'nt change! Can you help me??? Thanks you very much!
  • copytechman
    • Nov 2008
    • 969
    Do you have the service handbook? If so check that line mode is turned off.. it's an 08 mode setting..
    Regards!
    A.
    • mitsubee
      • 176
      e45 counter not counting
      try check on your 08 203 Value if 1 change to 0 if 0 change to 1 confirm can use
      • quocanh83
        mitsubee
        Thanks for your help mitsubee, i have done
        • quocanh83
          Ah, if 09 and then turn on/off ?
