5055c series cycle time
  • billmcwho
    • Jul 2020
    • 23
    have a customer that the copier cycling every minute is annoying. Is this cycle interval adjustable? TIA Bill
    • 23010
    Re: 5055c series cycle time
    It's closer to 90 seconds ... and no you can't stop it. It's designed to distribute the heat over the heat sleeve, and prevent flat spots on the pressure roller.
    You could set your sleep mode to two minutes, but every usage will require it to warm up/wake up. =^..^=
