Toshiba 7516ac color error
  • TP copy
    • Apr 2025
    • 6
    I have replaced the drum and charging grid, registered the color and adjusted the color but it still doesn't work, I hope everyone can help, thank you very much
    • 23009
    " ... doesn't help ... " doesn't tell me very much. If I knew what that image was supposed to look like, then I could offer some kind of opinion. How about this?:
    • TP copy
      • Apr 2025
      • 6
      The original image has been mixed in color, but it's printed like that
      • djbass
        • May 2008
        • 167
        It's still not clear what we are looking at, it would help to print a standard test chart.
        No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
        • Vincent128
          • Sep 2015
          • 349
          Or Mr. Blackcat's test files (highly recommend..much usefull)
          • djbass
            • May 2008
            • 167
            I'm curious what the advantage would be, the internal test charts tell you everything you could want to know if you know how to read them.
              • 23009
              For myself, I worked on nine brands of equipment, each with their own unique internal test charts and each with their own unique way to get to them. OR, you can use one common set of charts, that always have the same pattern, and can be used on any devise that prints from USB.
              Remember nine ways, or remember one way? For me, it's easier to remember one way, and they don't differ with manufacturer.
              • djbass
                • May 2008
                • 167
                That's fair. I would counter, though, that one size doesn't fit all, I also work on many brands and each have their own unique ways of colour rendering along with some using more bespoke imaging process so what looks good on one system doesn't necessarily look good on another.
                • Vincent128
                  • Sep 2015
                  • 349
                  Also..I simply like it better than the built-in Toshiba charts and the Lexmarks. Defects show up distinctly on Mr. Cats charts.
                  We all have our own ways of discerning and trouble shooting.
                    • 23009
                    @Tấn Phước Nguyễn
                    Would you like to post a test chart that we can recognize?
