3515ac toshiba adjusting, wait until printing error
  • TP copy
    • Apr 2025
    • 6
    Help 3515ac toshiba adjusting, wait until printing error
  • arnh79
    • 468
    That's not an error. It's telling you that it's doing a quality control adjustment and that the job will output after the adjustment is complete. If you're getting this a lot, it may mean you need to look at your IQC sensors or process units to see if there's any problems there.
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
      • 23009
      I agree. Check that the patch sensor shutter is opening & closing correctly. It's common for the hinge point to break, and the shutter to flop around like a broken wing. there's a modification for that.
      • djbass
        • May 2008
        • 167
        If it happens frequently or takes a long time, it can also be a sign that the fuser is not getting up to temperature. The fuser may require a rebuild, or very rarely, the thermistors in the fuser may be faulty.
        No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
        • TP copy
          • Apr 2025
          • 6
          Every time I print 2 to 3 sheets, it will be adjusted. Wait until it is printed...I changed the dryer and increased the drying temperature but it didn't run out
          • djbass
            • May 2008
            • 167
            Are you saying you replaced the entire fuser with another one?
            Increasing temperature won't help, the issue is not a specific temperature, but that the thermister in the fuser does not read the correct temperature. This can either be because the rollers and belt have worn, causing uneven temperature across the surface, the oil has dried out inside the belt, preventing transfer of heat, or the thermister itself is faulty and giving an incorrect temperature.
