4515 dead after firmware update.
  • Rusty.Harris
    • Jan 2021
    • 621
    Tech called me, said he was at a WORKING 4515, saw the firmware out of date. Did the update
    and it finished correctly. Upon reboot, dead display, just the power light steady. He pulled the
    cover, noticed an excessive amount of dust on the cover/fan/memory. Cleaned reinstalled memory
    held energy saver, powered up, still nothing. He called me and I had him try the system recovery
    file. That brought the machine up and it started working. He said that he went ahead and formatted
    the HDD and re-flashed the the machine, just in case something was still scrambled.
    I had him run HS/HDD check and everything was ok.
    So, I'm guessing something was messed up on the memory card when he flashed it?
    I'm just glad the Gen 3 machines have the memory hard wired to the system board.
    This "tin whisker" problem goes all the way back to the 5520 color & 855 b&w.
    Thought I'd pass this one along.
    • 8143
    "I'm just glad the Gen 3 machines have the memory hard wired to the system board."
    Did not know that and will do a visual check next time I am at the back on a eBN3/ OC3 copier.
    • Blizzoo
      • Aug 2013
      • 607
      everything new becomes smaller and smaller - just good to be thrown away and replaced with a whole component when problems arise.
