2550c and 55c developer unit
  • bruce 49dcs
    • Jan 2017
    • 140
    hello
    does anybody have rebuilt black dv units I can purchase or maybe the group of parts I might need to rebuild the units myself
    im a small independent tech and these units are the weak spot for these machines
    thanks very much
    • 23008
    Re: 2550c and 55c developer unit
    That's a fact. Most of the time if there's an error code, it's because you'll need to rebuild a developing unit. =^..^=
    • tsbservice
      Field tech
      • 8013
      From time of DP3500/4500 and then estudio 350 and so on I hated those developer units. Great B&W machines but those developer units were their doomsday. No mather how many times you rebuild them with oil seals, bushings, bearings and gears they will last up to 3rd maintanance and then better replace whole damn thing or tech is rewarded with damaged mixer shafts and developer sleeve shaft too.
      Knowing Toshiba(not particular models in question) they didn't changed design of these developer units, are they BC?
        • 23008
        There have been minor updates:
        different augers
        bearings all around instead of bushings (we've been doing that since the beginning)
        the 2505 and 2515 have incompatible parts that are essentially fail in exactly the same way.
        The short explanation is that rear seals fail, allowing developer into the bushings or bearings. It's a plastic auger shaft with a thin metal sleeve at the seal area. The thin sleeve wears through ... I've seen a few twisted off augers. The developer powder works as a polishing compound, polishing the teeth right off the developer gears.
        The newer 2505/2515 machines are actually worse: The air duct under the developing unit fills with developer, throwing off the toner density detection. As SOP, I remove the lower duct cover, vacuum out any developer, and tap as much developer as possible out of the toner sensor (it will be full). If you don't, the machine will not be able to perform a developer stir successfully. There is a new style mylar seal intended to keep that developer out of the duct. I can't say whether it works or not.
        • tsbservice
          Field tech
          • 8013
          different augers
          The newer 2505/2515 machines are actually worse: The air duct under the developing unit fills with developer, throwing off the toner density detection. As SOP, I remove the lower duct cover, vacuum out any developer, and tap as much developer as possible out of the toner sensor (it will be full). If you don't, the machine will not be able to perform a developer stir successfully. There is a new style mylar seal intended to keep that developer out of the duct. I can't say weather it works or not.
          Ouch... sounds like fun
          My Toshiba days are now gone though I can still rebuild dev units and fusers, but man they aren't missed at all
