F350 Error , LGC problem Toshiba 507
  • alireza7272
    • Aug 2017
    • 5
    [Error Code] F350 Error , LGC problem Toshiba 507
    Hello, I have a Toshiba 507 copier. This machine has an F350 error.my Firmware does not accept its version. Thank you for your guidance
    • 23009
    Re: F350 Error , LGC problem Toshiba 507
    Is it safe to say that you swapped a scanner PWB from another machine, but did not update the firmware?
    If it won't take firmware version 1286, you may need to replace the scanner PWB. =^..^=
    • mgipa
      • May 2020
      • 49
      Sys board erro
