Cpu fan error f400
  • sanjayalk1
    • Feb 2019
    • 10
    Cpu fan error f400
    Hi,
    I have this error
    Cpu fan error. F400
    From Toshiba eStudio 256SE
    I replaced the cpu fan but still error comes in boot and cant do anything
    But service mode are working 0+8
    Need help ...
    • 23008
    Re: Cpu fan error f400
    There isn't much to it: The system board fan, the system board & (2) connectors (CN112 & a union). That's it.
    Are you getting 24vdc at the fan connector?
    AFAIK there is not a 03 mode to test that fan motor. It runs constantly whenever the machine is on.
    Are you sure that it's the system board fan M6 that you changed?: It's here:
    • sanjayalk1
      • Feb 2019
      • 10
      [ATTACH=CONFIG]54265[/ATTACH]
      Thank you for reply,
      The fan change is m6 yes
      Tomorrow i can check voltage of giving to fan power connector and let you know
      • sanjayalk1
        • Feb 2019
        • 10
        Hi
        I checked voltage and cn112 connector comes 9.3vdc
        Fan voltage not 24vdc it shows 12vdc
        If anyone have circuit diagram manual i can check why 12vdc not create on connector cn112
        Thanks...
          • 23008
          It's unlikely to be a power supply. I'd say your best chances are with the system board.
          There's an odd chance that you've got a dead short or pinched wire in another component that's running off the same power supply lead. The next thing to do is determine which other components share the same connection to the power supply and disconnect those, to see if your supply voltage comes back up. =^..^=
          • sanjayalk1
            • Feb 2019
            • 10
            Hi
            I think this is not power problem, bcaz we gave 12v separately to the fan power and checked , still same error.
            I think fan signals not sent to correct path , to control ic.
            If anyone have circuite diagram of 256se it will help a lot to find the problem...
            Thx.
