studio256
  • arashardalan
    • Aug 2022
    • 4
    [Misc] studio256
    Hello
    The preparation speed of the device is too long. How can I reduce the preparation time?
    toshiba studio256
    • 23007
    Re: studio256
    Do you mean the warmup time to come to "Ready"?
    What media type settings are designated for each drawer?
    What is the toner level at? Maybe almost empty?
    What does your manual say about warmup time in seconds?
    How much slower than the specified time?
    If it was a higher speed LoireX I might suggest that the lower speed fuser had been installed ... but this one is supposed to have the lower speed fuser.
    Oh, I think I might know what you're talking about. The LoireX series had a new operating system that is unbearably slow at booting up. I've had machines take up to 30 minutes to boot up from OFF. There isn't really anything you can do about that.
    I remember one eS257 that the panel operated very very slowly, intermittently. Enduser says button must be pressed 3 or 4 times, but waiting 5sec after one press works. "Line is not detected" message.
    First I upgraded firmware to v. 1284 and panel calibration (08-9050) did not help. I suspect the system controller is continually searching for a network connection tying up resources. No network connection is present. Disable Down Link Detection: User Function > Admin > Password > 123456 > Network > Other > "Link Down Detection" Disable > OK > Apply Now > Close.
      • 8193
      Re: studio256
      Toshiba Tec Japan officially no longer supports the e256. This product was discontinued more than seven years ago.
      • arashardalan
        • Aug 2022
        • 4
        Re: studio256
        Unfortunately, due to the embargo, we still have to service analog devices. We have to service Toshiba models 1560-2860-16-160-350-352-353-...4528 from analog to the latest production of the company....... ....
        • arashardalan
          • Aug 2022
          • 4
          Re: studio256
          I am a Toshiba technician and have more than 20 years of sales and repair experience
          The problem is that the time from pressing the power button of the device that displays the Toshiba logo until the device is ready to use was usually between 2 and 4 minutes, but now it is 8 to 10 minutes.
          Colleagues must have experience in this case. I want to know how they make it
          For example, with the codes inside
          clear6
          clear3
            • 23007
            Re: studio256
            Good luck. that's just how they are.
            A firmware upgrade could take up to 1 hour, waiting for the machine to boot back up in 08 mode, after the firmware. I'm glad those machines are gone. =^..^=
            • Blizzoo
              • Aug 2013
              • 608
              Re: studio256
              Format HDD and reload FW, I had the same situation before and this fixed it.
              • arashardalan
                • Aug 2022
                • 4
                Re: studio256
                I don't have access to the new updated file. Hdd drive and how to format?
