e-studio 352,352,452,453 light copies
  • rocky246
    • Feb 2007
    • 91
    The dealership where I work has been a Toshiba dealer for about a two years. I was sent to Chicago to be trained on this model (1 1/2 years ago). We have nothing but complaints about these machines and their light CQ. I agree. I have tried to set the density higher, check the xerographic voltages, & set the transfer higher. Still the copies look light. Comparing 04-111 test copies with test copies on an e-studio 520, shows that the 520 solids are way better. I know were talking about two different machines, but you would think the CQ would be better. We are a KonicaMinolta dealer also. CQ on these machines is far better than the Toshibas. Are our expectations for these machines too high or is this the way these machines are?
  • ToshibaTech
    • Apr 2007
    • 580
    I don't know if you're expectations are too high but I have yet to have a customer complain about CQ being too light on a machine with maintained developer/drum etc... I have never had to adjust a HVT to solve a problem on a toshiba yet (jinx.) I can say that between a 520 series and a 452ish series my test chart will come out the same if I had just put a DV kit / Drum / Wires in both.. no doubt in my mind. I have noticed on toshibas in the optics you get a lot of dust build up towards the rear on the lamps for some reason which gives light copies.
    I will not give you service manuals or firmware.
    • tsbservice
      Field tech
      • 8020
      Check out Checker's web site.
      • isaac341
        es352,452 light image
        adj 05-201 hihger can get darker image
        • smiley
          • Aug 2008
          • 615
          right isaac is right.try to adjust toner density.08 200 for auto toner density adjustment or 08 201 for manual adjustment.this model is 2400x600dpi in copy.gud luck
          there is no glory without sacrifice
          • Harry
            • 228
            light copy
            have to clean the optik you would see the difference
            • RyanPacific
              Linux Ninja
              • 97
              Laser slit glass
              The laser slit glass gets dusty. Clean it off, it's right next to the drum.
              Service Business Equipment
              New, Used, Refurbished Copy Machines and Printers
              Copiers in Seattle, Kent, Tacoma and Bellevue
              • Naveed Shahid
                • May 2008
                • 162
                Toshiba 352 light
                Hello
                First u clean optic then add toner manually if print quality improve so u solve ur problem if not may be dust in laser unit need cleaning
                • Naveed Shahid
                  • May 2008
                  • 162
                  Toshiba 352 light
                  hello
                  First u clean optic then add toner manually i hope u solved ur problem if not may be dust in laser unit clean it may be u solved ur problem
                  best Reagrd
                  Naveed
                  • aalex_bom
                    • Jan 2008
                    • 214
                    light image
                    let change DEV KIT 3520.
