Laser Inkjet labels
    • 8147
    Laser Inkjet labels
    I was at a customer location yesterday with an old e2555c copier where the user was reusing Avery sheet labels and putting them through the bypass.
    Of course, eventually several of those labels peeled off and became attached to the transfer belt and black drum, destroying it.
    This forced a service call on the dealer and the extra cost of replacing the black drum.
    I scolded the customer that they cannot put partially used sheet labels through the copier anymore as the heat of the fuser loosens the remaining labels from the backing paper.
    I inspected the boxes of labels that the customer was using. Some were marked "laser" which is Ok and some were marked "Laser/Inkjet".
    I am wondering if the Laser/Inkjet labels should not be put through a copier?
  • mojorolla
    The Wolf
    • 2596
    Re: Laser Inkjet labels
    I tell customers not to use any "inkjet" labels in our Toshibas; they melt and turn into Shrinky Dinks. Laser / coper / heat treated only.
    I also tell them not to use "EZ Peel" labels. These labels do not have the border around the labels and they EZ Peel themselves onto drums, belts, and fusers. I always tell customer labels are a onetime print, you cannot print the same sheet over and over...but we all know that they do. One warning, then it becomes billable.
      • 22999
      If it doesn't say "laser" or more specifically says "inkjet" only, they will not work well in any laser based device.
      This was a huge thing with the Samsung desktop color laser printers. You could get a new printer for $99USD with starter cartridges (1/4 full). These customers are not going to buy the high end full gloss laser labels (they are too expensive), so they get the full gloss inkjet labels. Those inkjet labels would roll up like a sleeve around the heat sleeve, then shrink down tight until the fuser couldn't rotate any more.
      Naturally the manufacturers warranty does not cover stupidity, so the printers would get carried into our office ... then carried back out again. The replacement fuser cost more than the whole machine, then add labor. Quite a few were abandoned, and sat uselessly on our shelves for a while. =^..^=
        • 8147
        Avery manufactures their popular #5160 labels that states right on the front of the packaging "Mailing labels for Laser & Inkjet printers"
        I do not understand how two different technologies can use the same label media.
        Of course, the customer reads that and thinks it must be OK to put through their copier.
        • davidmtupper
          • Jul 2021
          • 326
          Typically an inkjet can print on any media that the ink can dry on, though quality may suffer. Top quality inkjet paper is often clay coated to enhance the drying and quality, but any plain, pulp-based paper will work in inkjet printers/copiers. If they make them for a laser then they will work in an inkjet (mostly), the reverse is not true.
          • pacman
            I can turn a screw...
            • 318
            At least they aren't running transparencies!!!
            I always advise the key op to not use inkjet labels, laser only. Unfortunately, key ops come and go so sometimes we get a zipped label.
            • davidmtupper
              • Jul 2021
              • 326
              Yup, that usually means a new fuser, at a minimum. Good news, that's a chargeable call, at least the second time.
              • pacman
                • 318
                We had a customer once when we were a Panasonic dealership. The old 250/350/450's had a mylar strip before the exit. Not ONLY did the get it wrapped around the fuser, but they managed to rip the mylar off as well.
                That was an expensive service call for them.
