Toshiba 4505AC colors mismatch
  • longyen.hcm@gmail.com
    • Jan 2023
    • 13
    Hi guys Im newbie and new to toshiba,
    my 4505AC has mismatch colors when printing or copy, i have done A-A but did not work, please help. As you guys can see magenta is always below the others. I also try to change Magenta drum to yellow but still no hope. Many thanks and wish you guys all the best.
    • 23009
    Re: Toshiba 4505AC colors mismatch
    Tell me about this "A-A". What is it?
    I was thinking that maybe a color calibration might be in order. Have you looked at your manual yet? =^..^=
      • 8229
      How many black and colour clicks are on the copier?
        • Jan 2023
        • 13
          • Jan 2023
          • 13
          Thank you for your reply, black is 5k and total color is 232k.
            • 8229
            With 232,000 colour clicks on the copier, the CMYK developers could be worn out.
            No amount of button pushing on the LCD panel is going to bring this copier back without new parts
            If nothing has been done to the copier to-date, many parts need to be replaced costing well over $1,000.00 and a lot of hours are needed to bring this copier back into working considtion.
            I would start by entering Service Mode and printing off the PM list from Code 103.
            I hope this copier is not under any service contract because someone is facing a big invoice to bring this copier back.
              • 8229
              I recommend you watch these two videos
              Toshiba eStudio 5055 Develper Rebuild - YouTube
              Toshiba eStudio 5055 Drum Unit Rebuild - YouTube
              Assemble all of the new CMYK replacement Developers, Drums, Grids, Needle Electrodes and 2nd Transfer roller that you need.
              It is less expensive to buy some off these parts by ordering a PM kit.
              Remove the same from the copier and rebuild them offsite.
              Then perform a colour calibration and registration from the LCD panel.
              The e4505AC is now two models back discontinued and should be replaced with a new copier.
                • Jan 2023
                • 13
                Many thanks for your replies, it means alot to me, ill look into it and try to do my best. Hope i can save this copier
                • mojorolla
                  The Wolf
                  • 2627
                  Have you tried the Color Deviation Adjustment?
                  05-9062, be sure to load bypass tray with paper before running this adjustment.
                  This will run 05-4719 first, which is color registration. If this fails before the pattern is printed, you most likely have a hardware issue.
                  • Blizzoo
                    • Aug 2013
                    • 608
                    What FW version your machine have?
                      • Jan 2023
                      • 13
