e-studio 2000ac color scan
  • bruce 49dcs
    • Jan 2017
    • 140
    just sold this a month ago and they are complaining they have to tell it to scan in color every time so im thinking its defaulted to black so i go in user settings go to scan and choose auto color and i think im good when we go to scan in the top right of the screen it shows the scan settings and i see auto color along with the resolution and others so we scan and go to the computer and its on the the computer in black and white ugh i went through the 08 settings and came up with 9116 to 0 and 9979 to 0 not sure if these codes will do anything im going back out tomorrow any help would be greatly appreciated
    bruce
    49 dollar copier svc
    ps
    also when i go through all the tabs for scan in user settings it says enter color initial value or something like that
    • 22999
    Re: e-studio 2000ac color scan
    It's been along time since I did it, but there are separate default settings in each scan shortcut. I usually end up re-creating the shortcut with the new settings that I want. =^..^=
      • 8144
      bruce
      ps
      If you acquired this copier through a used equipment broker, you should probably perform a factory reset under 2nd page of Admin menu and re-program the copier over again.
      When you say scan to the computer, via what method. FileShare or via network Folder?
      • Blizzoo
        • Aug 2013
        • 607
        You probably use scan templates and as blackcat said, when the template is created it will use the settings at the time of creation as the default settings. Have you tried to scan to USB, email, own HDD File Share? Use the Scan button to get the testing and not through the shortcut, if created.
