Issues with toner waste alerts e2525AC series
  • arnh79
    • 468
    Is anyone seeing early toner waste near full alerts on the new Toshiba series? I've had 2 machines send us alerts that toner waste is near full. One of them has 15k on it and the other has 29k. Both are about a 40/60 mix of color and black. The new series takes a TBFC425, but it looks nearly identical to the TBFC505 which was rated for 120k before needing replacement. I know we never saw any machine getting to 120k before replacement and that replacement times vary depending on ratio of color/black and toner coverage. But 15k and 29k seems awfully early to me to be generating a "near full" alert. Makes me wonder if there's a glitch. Just curious if I'm the only one seeing this?
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
    • 23009
    Re: Issues with toner waste alerts e2525AC series
    I know this sounds idiotic, but ... is your customer taking out the waste bottle and shaking it up, in the hopes that the "Add Toner" message will go away? Lol. =^..^=
    • arnh79
      • 468
      Ha! You know, it wouldn't be the first time customers have done silly things like that!
      But in these cases I have all toner and toner waste notifications on the screen turned off. No message will appear to the user until the toner waste or a toner cartridge needs to be replaced. We just get an email warning of near full and ship them out then. I don't think a customer could spoof that particular message. But never underestimate the power of a rogue enduser!
      If no one else is seeing this then I'd say these are flukes. Time will tell.
        • 8228
        I have asked the same question for you on Toshiba America's FYI.Toshiba.com service conversation area.
        I will post any responses.
          • 8228
          "Look at the pixel counter,
          It is very likely that the customer is using high coverage or running copies with the platen or DF cover open."
            • 8228
            "The waste box is rated for black = 120K and color = 30K.
            Most likely users are printing color documents."
            I did not know there was this lower capacity for color prints.
            • pacman
              I can turn a screw...
              • 318
              I had absolutely no idea - I just usually go by two black toners as a rule of thumb.
              • Vincent128
                • Sep 2015
                • 349
                the fun part is...when you have cloud policy setup for WT near full...If the customer replaces a WT before it says its fully full, the message dosn't reset.
                the machine has no idea that you put in a new WT...so I get a crap ton of WT near empty but the alternative is the machine skips the WT low alert and goes direct to WT full and shuts the machine down.
