Toshiba 2555C hard drive failure F101-1
  • Wild140!
    • Jul 2021
    • 16
    Is there a way to recapture the firmware of the unit before the HDD is replaced?
    I see in the SM that the backup should be.
    Perform [3C] - [5] (Key Backup Restore) and checkthat each Key Status is "OK".
    - If not, recover the key (copy "SRAM Key Status" to
    "FROM Key Status" or vice versa).
    In this mode I see 4 choices,
    what is the correct choice/choices to save the information to the thumb drive?
    Also is there a size restriction on the thumb drive seeing that it is an older unit?
    • 8143
    Re: Toshiba 2555C hard drive failure F101-1
    The 2555c series of copiers were prone to HDD failures. Should the HDD be dead you can only use a Toshiba original SED-HDD to replace it due to the embedded encryption keys.
    The HDD on the following generation of copiers rarely failed.
    You can use up to an 8 GB thumb drive formatted in either FAT32 or exFAT but not NTFS.
    • Wild140!
      • Jul 2021
      • 16
      Just to be clear you cannot recover this information from the sram of the machine?
      Also, I wrote the incorrect model it is a 2550C.
        • 22997
        No, you cannot recover firmware or any other data from a dead HDD. You also cannot copy data from another HDD to a new HDD, or move a working HDD without re-loading firmware. These are encrypting HDD's, and firmware must be loaded through the machine (cannot be pre-loaded). =^..^=
        • copytech,mike
          CopyTech,MIKE
          • Jun 2014
          • 261
          What do you mean "move the HDD?
            • 22997
            I mean that you cannot take a working hard drive off another machine, install it onto your machine, and expect it to immediately boot up. The HDD from another machine must be formatted, then re-loaded with firmware using this machine's encryption key.
            • tsbservice
              Field tech
              • 7974
              1. Get part from working machine.
              2. Put that part in troubled machine.
              3. Problem solved(or not).
              Basic troubleshooting you know
              • copytech,mike
                CopyTech,MIKE
                • Jun 2014
                • 261
                Ok i will buy that. For Canon ive swaped out a HDD with a used HDD and booted up. Not sure about the new DX series. On the older Estudio i was able to put in a new toshiba HDD and do format in service mode and it booted right on up. Its was back in 2004 when i was a toshiba tech. On my own now! Also, Konica Minolta is sweet! You can simply turn the HDD off and still use the copier!
