New Toshiba Toner Levels
  • mojorolla
    The Wolf
    • 2639
    Had a chance to build a 5525AC this morning. For the North American market, these are defaulted to show toner levels as "good", "less", or "empty".
    This can be changed to 1% intervals by setting 08-8870 to a value of 0. Setting the value to 1 displays 10% intervals.
  • Rusty.Harris
    • Jan 2021
    • 639
    Re: New Toshiba Toner Levels
    Yep, that code is in my list of codes I change when we set them up. Everyone prefers the "gas gauge" over
    the other way.
    • martin_s99
      • Jan 2024
      • 2
      I would like to do this on a Toshiba 2525AC, it is currently just showing good for the toner levels. I cannot find out how to do this, can this change be made in the copier web interface, if so where is the setting? Thanks in advance for your help.
      • mojorolla
        The Wolf
        • 2639
        This change is made in 08 service mode, select classic mode, then enter 8870, start, set value then press OK. Re-boot.
