Settings Reverting on e-Studio 3508a
  • MakingIT
    • Jul 2023
    • 1
    I have 2 e-Studio 3508a's and one has a mind of it's own...at least when it comes to certain settings, the other is normal.
    I disable SNTP Service and clear out both the primary and secondary addresses through TopAccess and confirm the settings were applied by logging out and logging back in. If I reboot the machine or after a couple of hours, SNTP is enabled with addresses. There are a few other settings that get reverted if I enable super sleep it will go back to disabled along with disabling then embedded application "Enable Application" it will go back to enabled. I haven't seen this before and this does not occur on the other machine.
    ANY help/hints would be greatly appreciated.
    Thanks!
  • Rusty.Harris
    • Jan 2021
    • 639
    Re: Settings Reverting on e-Studio 3508a
    We just had a 4505 that "had a mind of it's own" that would power itself off then on EXACTLY at one hour intervals.
    What finally fixed it was doing the 08-8615/16 decommission.
    If all else fails, sometimes wiping them out back to factory is the only fix.
