Estudio 2050c coin op
  • Cornnatron
    • Sep 2023
    • 6
  • Cornnatron
    • Sep 2023
    • 6
    Re: Estudio 2050c coin op
    Also would this wifi adapter work in the unit
    link?
    • Cornnatron
      • Sep 2023
      • 6
      Ive managed to disable the coin mech in the options through 08-9016 on 0 and disconnected the cables so thats done only thing left is to get wifi on it if possible ive seen that a card of the size posted earlier would fit question remains would that work and if so would i need to do more after pluging it in to get it working. Cause i have seen a option for wifi in the menu.
        • 8259
        Introduced in 2012 and discontinued in 2016, all support from Toshiba Tec Japan is scheduled to cease on April 2024.
        I have none of this model left in the field and I try and forget everything I knew about them.
        Wireless was never a very popular option on this copier. You are better off running a network cable to the copier.
        Using 3rd party wireless adaptors is not supported.
        • Cornnatron
          • Sep 2023
          • 6
          Thx for that info i completly get what your saying.
          But i still see it as a score for myself specialy with all the extra toners i got with it for the price and knowing the machine hasnt got many prints/copies on it for what it can do.as its a machine out of a supermarkt where it did just over 52000 copies till now which is nothing for a machine like this i believe and here im only gonna use it to print some drawings so no heavy printing.
          And the fact its a laser printer with extra toners for less than 2 new hp inkt cartridges suits me fine. Lol
            • 8259
            Great! The copier should last you without issues until about 50-60,000 colour prints. Black prints are relatively inexpensive to repair.
            • Cornnatron
              • Sep 2023
              • 6
              Lol it done less than 6000 color prints i believe from what i saw before but couldnt find the option anymore to see what it had done in its lifetime. Will have a look for it again tomorrow
              Dont remember if i saw it on the touch screen or in a printed report .
              It wasnt much anyways as color prints where 3x as much as a b&w print back when it was in the supermarket so people would go for b&w quicker.
              • francisco junior
                • Jan 2024
                • 2
                Cornnatron, i have the same problem about "insert coin". How can i access 08-9016? Where i must to type these numbers please? I have no found the coins collectors around my machine. Could it had been removed before i take it?
                • Cornnatron
                  • Sep 2023
                  • 6
                  It could have been removed before yes , and for the code that is located in the service menu , watch one of vid on yt on how to enter that and ones in sub menu 8 find code 9016 and put on 0, if i remember correctly you could double check the service manual to be sure , should be able to find that online somewhere.
                  • francisco junior
                    • Jan 2024
                    • 2
                    Thank you mate. I will have a look!!
