Toshiba eStudio 2540c - Magenta Band Along Top of Paper
  • jsands
    • Oct 2019
    • 11
    Hi all - Toshiba eStudio 2540c machine required a main charger and slit glass clean (normal routine) but now prints a magenta stripe along the top of the paper. Pretty simple fix for you guys! Can you help? Thanks.
    • 23010
    Re: Toshiba eStudio 2540c - Magenta Band Along Top of Paper
    I think an image sample would help us, to help you. Mark the paper feed direction on your sample. =^..^=
    • jayschrodter
      • Dec 2012
      • 36
      Cracked end block probably, they leak. Sand and clean or replace charge grid. Replace with new end block and fit and tap with plastic screws to stop the problem from reoccurring. Well that is until the charge lever breaks lol
