A great Toshiba YouTube channel
    • 7867
    Lots of helpful repair videos made by an experienced Toshiba tech.
    Hadley Hudson aka "The copydoc" - YouTube
    If you want him to make any more videos just ask.
    • 7867
    Re: A great Toshiba YouTube channel
    A new video about Toshiba's Doc feeders. Cleaning the slit glass and changing the paper feed rollers.
    Toshiba document feeder solutions - YouTube
    • tsbservice
      Field tech
      • 7627
      Extremely stupid for Toshiba to let the Mr. Customer change the rollers. Teach them also to blow off the sensors and clean transport rollers
        • 7867
        ... the videos are aimed at rookie and experienced Toshiba copier techs who really appreciate the easy to follow instruction.
        In other videos on this site, there are instructions on how to blow off the sensors and clean transport rollers.
        Depending on the situation and how far away the customer is, these videos can save both a lot of time and money.
        • tsbservice
          Field tech
          • 7627
          You Tube engineering at its best. It used to be in service manuals and it is at least for brands I service now. Nothing against techs learning from watching tube.
          • Hadster
            • Aug 2011
            • 264
            Exactly! I started this company up selling rebuilt Ricoh's on Craigs List, so some of my customers where 4 to 5 hours away. They were told at the time of sale to have the local service rep service the machine. But, they kept calling me for help anyways. SO, that's how all of this got started. I would send them the part, make a video and they would install. Saved time, money and made for very happy customers that to this day still buy copiers off of me 12yrs later.
            Hadley "Copydoc"
              • 7867
              Toshiba 2000ac, 2500ac, 2010ac, 2510 (PM) preventive maintenance
              Toshiba 2000ac, 2500ac, 2010ac, 2510 (PM) preventive maintenance - YouTube
              ... I learn stuff with every video.
                • 7867
                Bypass tire replacement for Toshiba copiers
                Bypass tire replacement for Toshiba copiers - YouTube
                  • 7867
                  Hadley "Copydoc"
                  Are you able to comment on this?
                  Re: Toshiba 3015AC color developer
                  I have put k developer in the color units. Toshiba will say you can't. The color will obviously be off at first but if you just run 100 full color copy's and consume the k toner that comes premixed with the developer, it eventually will dump enough new color toner in the unit to where it looks normal. I've done this many times and it hasn't caused any issues. I've even went as for to jump series. One time I threw in some toner from a 2440ac into a 4515ac and had no issue. No auto toner sensor issues, no dirty copies. I'll run auto toner sensor calibration and recalibrate image quality charts. Idk sometimes I think they just say you can't do certain things as to make more money.
                  • Hadster
                    • Aug 2011
                    • 264
                    I had to run several hundred sky shots but it finally replenished the magenta toner (3505AC) using K developer in the magenta developer unit. I don't see an issue with doing this. After running the sky shots, adjusting the auto toner sensor, closed-loop control and registration all is well.
                      • 7867
                      ... so this could be a big money saver, because CMY Developer is so expensive?
                      It does cost some extra time.
                      In Canada, e3505AC K Developer cost $160.53 CMY Developer cost $686.61 each from the OEM.
                      On the e3515AC and e3525AC, the Developer cost even more.
                      By several hundred, do you mean 200 to 300 skyshots with max toner on the page?
                      • Hadster
                        • Aug 2011
                        • 264
                        Yes, about 300. I place a letter size paper on lead edge of platen glass about 2 inches to keep from jamming when running sky shots.
                          • 7867
                          ... another Toshiba copier repair channel that I found.
                          Jamming in the Document Feeder
                          Jamming in the Document Feeder - YouTube
                            • 7867
                            I used this video today to clear out a jam caused by a staple in the e2555c Doc feeder using thick paper.
                              • 7867
                              Rotate Sort
                              Rotate Sort - YouTube
                              A great video on dealing with torn originals going through the Doc Feeder and how to quickly create one touch butons using the Home+ button.
