De-tone a 2050C
  • wyo19
    • Nov 2012
    • 51
    De-tone a 2050C
    I have a machine that is way overtoned and need to run sky shots to do this without the machine adding toner. Is there a code for this?
    Also, this was caused by a tech turning off the patch adjustments 05-2742 05-4719
  • hidius
    • Jun 2015
    • 128
    Re: De-tone a 2050C
    remove the toner bottle and do sky shots untill it tells you to insert toner bottle. i know it works on the newer machines but dont know about these older ones. also usually if its overtoning the toner sensor cleaning blade on the auger is probably on its way out and needs replacing
      • 22999
      Re: De-tone a 2050C
      You won't get any long term benefit ... but feel free to try. Use originals like this:
