MJ-1048 + 3025AC
  • Rusty.Harris
    • Jan 2021
    • 639
    MJ-1048 + 3025AC
    Been in the field since October. Tech said it would say finisher not recognized. Brought the finisher in to the office,
    couldn't see anything obvious. Tech sent the board to hitech for warranty repair. Came back no problem found.
    So, started from scratch, checked the wire continuity. Pin 7, (yellow) from the connector that connects to the copier,
    UNDER the torrid coil was broken. Since it is on the back of the machine, not really in plain view of the end user, just
    soldiered it back, put the heat shrink back over it, wrapped it with tape to call it good.
    • 8322
    Re: MJ-1048 + 3025AC
    [ATTACH=CONFIG]61384[/ATTACH]
    Tough one to spot in the field.
