CA21
  • sappa12
    • Sep 2023
    • 57
    CA21
    Hello,
    sometimes i just need good old debate for a problem
    we got some used e-3015. i did a full maintanance and noticed some white lines on copies. I put laser unit out and opened the upper cover to clean glass from inside(like i done this many times), so when i put all together i get an error code CA21 wich is H-sych problem on K. I swapped with another laser unit and machine works fine. Since laser unit is expensive i try to figure it out why i get this error code.I have some old laser from 05 series and swapped polygon motor,all laser diode and all flap cables but still getting CA21 error. i suspect this small pcb board LRL,but its just an intermediate board to LGC board. I just want to explain to myself what the hell went wrong lol
    so any idea or experiance is appriciated
  • Rusty.Harris
    • Jan 2021
    • 631
    Service tip
    This was on the last monthly service meeting. Don't know if it will help, but probably couldn't hurt.
    • sappa12
      • Sep 2023
      • 57
      Re: CA21
      R.H. i did try that but no luck. thx for the input,i will be more carefull next time around laser unit
      • Rusty.Harris
        • Jan 2021
        • 631
        Re: CA21
        As a last resort, you could always send it to Hytec, and have them repair it. Cheaper than a new one.
