Toner cartridge warning
  • sappa12
    • Sep 2023
    • 57
    hello
    I get this used machine e-3515 with 1 to 10% toner levels...my boss said to change it with new ones,and we just swap the new ones in...but now i get this warning message "Black toner cartridge was replaced before empty.Please reinsert previous cartridge.And use until empty"....and icon replace cartridge is gray.
    i checked 08 code 3632 and its 0 and scroll entire manual and didnt find anything to avoid that restriction
    any help appriciated
    ...and i dont have old toners anymore
    • 8197
    Try 08-4866-0
    • sappa12
      • Sep 2023
      • 57
      thx....i did, and nothing changes
      • doxtar88
        • 11
        You can try 08-9022 to 0 then restart machine, so when you turn on then machine it will do the factory settings as new and ask you for the toners.
        • sappa12
          • Sep 2023
          • 57
          Thx...good to know
          For now i did manage to tricked the system with some empty cartridge and making dark copies to use all toner from dev unit
            • 8197
            What firmware is the copier at? 08-9900 .
            Latest is called FW2100.
            • sappa12
              • Sep 2023
              • 57
              Yes,its a 2100
              I did all the usuall stuff,factory reset,hdd format,new fw...and still hold this settings.
              Maybe its a special settings from toshiba like low color couter wich you canot find it in service manuals.
              I cant ask the salesman because he is just a dealer and from other country.
              But its a usefull settings if customer change toner before end...everytime he opens front door he get this message for changing toner before end and its realy annoying
              • mojorolla
                The Wolf
                • 2618
                08-3632 will turn off the message when they open the front door.
                Sets the display of the early time toner replacement
                prevention message when the front cover is
                opened.
                0: Not displayed
                1: Displayed at the toner-near empty
                2: Always displayed
                • sappa12
                  • Sep 2023
                  • 57
                  That was my first try and didnt work...must be some other "setting" because i also have a grey "replace cartridge" icon when you check the % of toners
                  • mojorolla
                    The Wolf
                    • 2618
                    My bad, I rush read your original post. In that case...
                    run 08-4833 (recovery from empty toner/full wtc)
                    run 08-5155 set to 4. Then set 08-5810 set values 0-3 to 1 %. This set when the machine displays a low toner warning, default is 5%
                    run 08-3632 set to 0.
                      • 8197
                      It seems FW2100 was withdrawn from FYI.toshiba.com due to several issues.
