Printing Envelopes on Toshiba 3511?
  • CopyDawg
    • Dec 2008
    • 74
    Does anyone know how to properly set the Toshiba 3511 to print envelopes from the bypass tray? It doesnt seem to allow you to set the exact size of your paper, and even though my customer is setting the document up as an envelope on her computer...the Copier just keeps recognizing it as Letter sized paper. Any suggestions would be most appreciated.
    Thanks!
  • copytechman
    • Nov 2008
    • 950
    That machine doesn't officially support com10 envelopes (or any kind for that matter). Despite the driver setting. I wouldn't use it for that.
    At least it didnt when I was working with those machines!
    Regards.
    A.
    • ToshibaTech
      • Apr 2007
      • 580
      I agree with copytechman .. you are only going to give yourself headaches if you try to print envelopes on a Toshiba. The 280/2/3 series support it but only one at a time through the bypass. That's the answer I give customers or salesmen. Some models (not 3511 I think) have 08 code 449 which turns of paper jams due to size errors. I --think-- you might be able to use that to fool the machine into printing on an envelope. I.E. MS Word would send the envelope as letter, you have an envelope loaded, the machine prints on the envelope and doesn't jam because it's not the right size. If this works you would run the risk of someone printing on the wrong size many times and dusting toner everywhere. (Say they loaded the tray with LT and printed a bunch of full coverage LD documents.)
      I will not give you service manuals or firmware.
      • Wattman
        I just can't believe it!
        I'm just a user and own a very nice 3511 which I have in my home office - but it is so hard to believe that a manufacture would design, built and market a "Business Printer/Copier" for the Business World and it can not print at least a business envelope - I would think I could purchase a printer from Wal-mart capable of that, but maybe not!
        • CJD900
          • Nov 2009
          • 18
          The reason for this is because anything faster than a 280/2/3 will crease or crumple the envelope. So it has to do with the actual speed of the MFP.
          • Mr Spock
            Vulcan Inventor of Death
            • Aug 2006
            • 2064
            Also when I went to training you could "trick" it into printing envelopes by using the actual size of the envelopes but you can not use color they have to be black and white only.
