what type of files are you trying to print? And what is the size of them?
Did you try connect the machine directly to one computer? this will confirm if is a problem from the machine or the network. In the computer go to German site from toshiba and download the newest drive to this machine, then choose the LPR protocol and un-check the "LPR Byte Counting enable" and "SNMP Status Enable" this can slow down the machine and in the "Queue Name" write PRINT. Then print and see what the size of the file in the printer.
