Toshiba EStudio 28
  • slloyd2
    Toshiba EStudio 28
    Hello,
    I had th epower flicker a fwe times and now the estudio when i turn it on will only briefly light up and then it goes black. Is there a fuse or something?
    Shawn
  • Paper_path
    • Jul 2009
    • 55
    Power Supply
    Turn off the copier and unplug it from the wall. After a minute plug it back in and start it up. This will reset the power supply, if it doesnt work after a few tries, your power supply may have been damaged.
    • JustManuals
      • Jan 2006
      • 9838
      And if that doesn't fix it, call a qualified technician.
      Paul@justmanuals.com
      • mitsubee
        • 176
        izzit toshiba DP2800 or es280? for DP2800 it always have this problem...the power board is super sensitive...try to plug-into a supply which is NOT shared by too many device..
        Thank and hope this would help
