E723 CA90
+ More Options
Posts
  • scepter2112
    • May 2009
    • 72
    E723 CA90
    I have two Machine E723 throwing CA90 code intermittently all looks ok. any hints out there. Two LGC or SYS pcbs at same location odds are to astronomical for me
  • audioimaging
    • Jul 2009
    • 73
    Firmware level 330 has a fix for this problem.
    • scepter2112
      • May 2009
      • 72
      Thank you Audioimaging. Once again I fixed the problem by accident, LOL. The last thing I did before leaving upgraded F/W to V340. I researched problem and did not find that piece of Info, where did you find it?
      • audioimaging
        • Jul 2009
        • 73
        Look in the copier rom history on tech to go. This gives you a list of what's included in each new firmware version.
        Under version 330, it states "on some occasions where a large number of single page originals were duplex printed or copied, you could get a CA90 error. This issue is corrected.
        I remembered from having this issue on a machine some time ago.
