3511 - Light print from computer
  • macmedic
    • May 2009
    • 20
    I will also say thankyou..
    I just did a few colour copies of a very colorful A4 i tested when we first got the copier vs previous calibration to now, and the colour and quality of the print is better then ever!
    The only problem left now is a bit of a rolling print error where the is toner missing off the page. I think this is a drum issue, but will post as a secondary issue.
    Thanks guys - I hope this thread helps others.
    • macmedic
      • May 2009
      • 20
      Originally posted by ToshibaTech
      In layman's terms you need to remove everything you can see inside the machine (not the revolver, but transfer belt, drum unit, dv unit) and vacuum/clean all the toner that is most likely piled up all over the place. There are position/registration sensors in the transfer belt unit so I'd blow it out good, the density sensor over the revolver and IQ sensor under the right end (transfer) of the belt. Clean your scanner optics also. Then do 05-395, then do your calibrations from user functions / admin mode. That'll be about as good as it gets without putting parts in it. Oh, make sure you don't touch the grey refrence plate on the density sensor over the revolver.
      Im sure getting to the transfer belt and cleaning the sensors would make the print as good as new, but I dont think i am skilled enough to do so unfortunately. Well I probably am, but unless the machine dies or persistently gets errors, I dont want to screw around. I hate working with developer - i learned the hard way about developer about 10 years ago when I emptied some out of a copier when i got the shits thinking it was the waste toner.. lol - whoops
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        Check on the right hand door for a black roller. Check this for gaps or the rubber/vinyl seperating from the foam core. These go bad just by looking at them. Usually the c/q issues show up as diagonal bands on the copies but not always.
        • fireater
          Repair God? not quite
          • Apr 2006
          • 253
          #19
          future reference. these are dusty machines. you will be doing this regularly. also the colour dev should always be kept within pm limits and yes USE
          the dev for the newer e-studio 351c series NOT the 3511 dev.... This is a Toshiba recomended update
          I fix copiers ...Well Sorta
          • macmedic
            • May 2009
            • 20
            #20
            This is the bad print i have been getting since I got the copier. This is a full A3, the repetition is too small to be the transfer or the drum, I would think its the fuser.
            Anyone have any comments or seen this before? tends to get worse along the page as you can see
            • emujo
              • Jun 2009
              • 3009
              #21
              Looks like a 2nd transfer roller problem. Open right door, you will see a black roller about 20" long. Foam covered by rubber/vinyl. Look for bunching, wrinkling, loss of the vinyl. The pattern you posted is about the circumferance of this roller. The Image Quality sensors look at the pattern on the x-fer belt before it is transferred so this would not be the source of the CE40 error codes. It might be worth the $200-250 it will take to have this roller replaced and the MFP professionaly cleaned up. And I aggree with previous posts, this MFP is a dust bunny. If you have the money, there are many upgrades that can help with the dusting probelm including 351C developer, new gap tolerances on the DV units, an anti dusting kit. EMujo
              • macmedic
                • May 2009
                • 20
                #22
                The roller looks fine, the vinyl is coming off the foam. The unit is very clean now. Unfortunately toshiba in Sydney a fortune to do anything to the unit and third party toshiba repairers say no and slam the phone when they hear its a 3511. I have another 3511, maybe I will swap this transfer roller to test.. is there any issues doing this?
                Is there a way to clean the roller if its just dirty?
                • fireater
                  • Apr 2006
                  • 253
                  #23
                  roller rarely need cleaning but t he vinyl cover always slips and bunches.... there has been 3 updates to this one..... swap it out with a used one is fine..... take note of the conductive grease at the rear side
                  • fireater
                    • Apr 2006
                    • 253
                    #24
                    by the way if the roller is not the problem run some copies with the transfer belt cover off so u can see the image on the belt to eliminiate the possibility of the belt being the problem
                    • emujo
                      • Jun 2009
                      • 3009
                      #25
                      Part# for the roller is 6LA27421000, doesn't sub for different areas so if you can get one from the US, it may be a little less and it will work. EMujo
                      • macmedic
                        • May 2009
                        • 20
                        #26
                        Sorry I should have said the vinyl IS NOT coming off the foam. the roller looks fine. Can I remove the roller for beter inspection and swap with my other copier?
                        • ToshibaTech
                          • Apr 2007
                          • 580
                          #27
                          Could be transfer belt drive problems or possible the revolver has some slop in it. The revolver should be tight front to back of the machine and rotationally. You could print out some fine red, blue, green lines and see under magnification if the colors are registered. If they aren't registered there are belts that wear out in the transfer belt drive and if you think taking apart a developer or transfer unit is bad I won't mention changing it out. You could still blow the transfer belt unit out maybe the sensors are being flakey on color registration.
                          I will not give you service manuals or firmware.
                          • copytechman
                            • Nov 2008
                            • 929
                            #28
                            I feel 4 u I really do, I was on one of the first canadian training courses for this dog... The pitch in your example looks to be either 2nd transfer or perhaps a contaminant on the 1st transfer roller itself.. its too small I believe to be the fuser belt or roller I think... and don't get me goin' on the transfer belt drive mod... just.. don't! lol.. like in previous post's i'd swap the 2nd xfer from the other unit just to see/isolate your issue and definately run ALL cq adjustments.. the machine will complain also if they aren't done in the correct order. The CF40 has to do with the colour auto-toner sensor not working quite right, thats a stinker cuz it can be anything from bad dev, contaminated toner, a dirty sensor, or even an improperly set doctor gap.. you can check which colour dev unit it's erroring out on tho, it's in the 0-8 modes... are you familiar with those? 08-823-0 to 08-823-2 (Y-M-C) where a result of 1 = the unit that doesn't want to tone properly.
                            Good luck and regards!
                            A.
                            • emujo
                              • Jun 2009
                              • 3009
                              #29
                              If the vinyl cover starts to wrinkle at one end you would see the same CQ issue. The only last 60K at best. EMujo
