Estudio 6530c ticking noise at idle
  • toddanderson
    • Dec 2005
    • 236
    I am a new toshiba dealer , so I don't know if its normal
    but when the 6530c sits at idle you here a ticking noise at random
    we have two machines doing the same.
    question - when the machine sits at idle do you here a ticking noise from the
    fuser ?
  • toshibadale
    • Apr 2007
    • 117
    Ticking
    The only noise I've heard is from a fan. I've never heard it from the fuser.
    • toddanderson
      • Dec 2005
      • 236
      Fan ?
      It is difficult to tell, I may have a fan problem
      What fan , are you talking about
      Thank you
      • Travis06
        Tech.
        • 193
        there is a modificaton kit for the ticking sound. it includes new gears, bushings and spacer. takes about 20 minutes to install
        • toddanderson
          • Dec 2005
          • 236
          Color bulletin 138 or 144
          What mod kit ?
          are you talking about color 138 or 144 bulletin ?
          • Travis06
            Tech.
            • 193
            p/n 6GAPBFUSMOD
            Even though the serial number might fall within "modified" from factory machines. I have seen some with the bracket but old bushings and no spacer. I think the spacer makes the most sense. You can use a lower pressure roller bearing (from a 450 ect...)as a spacer between frame and bracket if you don't want to waste a whole kit.
            • Travis06
              Tech.
              • 193
              one more thing. make sure you set the machine to go into power save and you shut the machine down properly. these fusers must "cam out" to save the stress on the fuser. otherwise you are replacing fuser belts every 100K and replacing gears too much.
              • audioimaging
                • Jul 2009
                • 73
                There is actually a new mod specifically for the ticking noise from the fuser. It is buried in the bulletin 144.
                Bulletin 138 dealt with gear failure and rather obnoxious noise from a broken frame on the fuser drive assy. I've experienced this failure and it's not pretty.
                The ticking is harmless but annoying. I am getting ready to install those pieces on a machine next week that was just delivered to a customer. Oddly, she found the sound bothersome.
                • toddanderson
                  • Dec 2005
                  • 236
                  yes i see that now
                  Thank you ,
                  Yes i see that now on page 6 of 144
                  Yes our sales dept is complaining on the noise
                  Thanks for your help
