e-studio 4511 copy with lots of developer
  • TTL
    • Dec 2008
    • 127
    Hi.
    In one Toshiba E-studio 4511, the copies is showing like this..
    http://img229.imageshack.us/img229/9080/doc091218.pdf
    This are a counter from the machines. In the copy or print is the same.
    I start to clean all the machine, now its better, but remains very bad.
    Some ideas?
  • emujo
    • Jun 2009
    • 3009
    Looks like either a charge problem, or the HVT that powers the charge system. When you slide the drum carriage assembly into place, do you encounter any resistance, espacially during the last 1/2 inch or so? If you felt resistance previously, and just continued pushing, you may have damaged the connector that routs charge, grid, and bias voltage to the drum, and black developer. Look closely for bent/broken contacts. You might try to disconnect the charge wire from the HVT and see if you get a solid black copy. Let us know...I've never seen CQ that blotchy. EMujo
    • TTL
      • Dec 2008
      • 127
      now that you say that, I think that the drum have some resistance in the ending.
      I go see that, and then I say something here.
      Thanks.
      • tinnyjay
        • Oct 2009
        • 655
        I think you must try a cleaning of drum and transfer belt.
        If nothing happens you must change the drum and the drum cleaner.
        "Who loves the roses,must also bear thumbs"
        • TTL
          • Dec 2008
          • 127
          it was a problem with the HVT board.
          when the board was changed all back to normal..
