I am working on an e-Studio 282 that customer claims when they try to make a copy or when faxes come in, the copier may print 2 or 3 pages then starts to cycle for a long time. They open the right door to stop the cycling, then they may print 2 or 3 more print and continuous to cycle. I went to verify what the copier was doing but upon arrival had a C440. It turned out a screw had fallen off 1 of the heater lamps. I reinstalled it, tested ok. The next day customer says the machine keep cycling again. I went back there again and the machine was working fine. Checked fuser and all ok. It also has a brand new toner (OEM). I recently delivered this machine and prior to delivery I replaced the heat roller with a generic Katun brand.
At this point I'm not sure if the cycling problem is with fuser temperature or with the imaging unit.
My question is if anyone has had this problem and what was the solution?
Thanks in advance.
Claudio
Thanks in advance.
Claudio
