Toshiba Studio 850 Wait Warning Up
  • MiguelRT44
    • Aug 2025
    problem with toshiba studio 850, you change the hard drive, then you install the firmware, but the machine there is lit with the message Warning Wait Up and trying to enter the message to 08
    MACHINE ERROR INFORMATION
    ENERGY SAVER LONG KEY PRESS
    I did the firmware installations step by step as indicated in the manual with the USB storage and complete everything well but gave no error when going into the 08-947 I get the message mentioned above, please if someone could help me with this problem thanks
  • richnokes
    I had one giving me almost the exact problem. I ended up rebuilding the fuser with new thermistor/thermistats and the problem went away.
    • MiguelRT44
      replace the fuser unit and continues with the same problem
      • ivovb
        • 695
        Are you sure You are using right firmware? Please give the name of the zip file.
        Concerning initial problem - change fuser tract power cable between machine and connector mounted on the back of the machine.
        BR
        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
        • emujo
          • Jun 2009
          • 3009
          You have a firmware problem. Most often occurs when you go from a low version to the latest version without the necessary "steps". Seen it happen when SYS bd is replaced and it is at ver 340. Re-load version 300 1st, then update to latest version. This should take care of the problem. Emujo
          • Mr Spock
            Vulcan Inventor of Death
            • Aug 2006
            • 2064
            I have seen this and the correction for me was just like EMUJO stated..
            • van hien
              You could switch off the copier then after 10 seconds you turn it on. It could be an error on the roller fuser reading too.
              • MiguelRT44
                this is the firmware version is installed on the computere-STUDIO850-System ROM Ver.330-T390ALLE059USB I think is the latest version and that version had not before installing this if I can facilitate an earlier version and try installing a previous version back to this please if I can help with this problem thanks
                • tech07
                  • Aug 2008
                  • 410
                  wait
                  all above answers are correct....but check drum thermistor also
                  • MiguelRT44
                    Please help me to get a version that I can serve I have is the 330 version if not the last, but if I could try some before and solve my problem two months ago my client machine, my email is msosaster@gmail.com
