eStudio 850 Streaks
  • mrfuser
    • 1617
    eStudio 850 Streaks
    Okay, we swapped out the drum, blade, transfer belt, cleaned everything and we are still getting light random streaks on the page going from exit to entrance direction. If we stop the page under the drum when cheated the streaks are on the page, but strangely enough we don't see them on the belt or drum. We removed the rear flywheel to check for loose screws and all seemed fine.
    Any ideas?
    Kelly
  • toshibadale
    • Apr 2007
    • 117
    There is a slit glass above the drum carriage unit that gets dirty. Pull it and clean it and your streaks will disappear!
    • mrfuser
      • 1617
      I actually did that when "cleaning everything". Still streaks.
      Anyone else?
      Kelly
      • ToshibaTech
        • Apr 2007
        • 580
        Is there build up on the mag rollers by chance? Also I have seen poor belt cleaning cause streaks on the back of the page of course. Make sure the cleaning brush inside the cleaner portion of the drum unit is in good condition (not hardened.)
        I will not give you service manuals or firmware.
