E-studio45 Error Code C47
  • expresscopycenter
    • Aug 2025
    Pls help me with my studio45 with error code C47... thanks ahead
  • expresscopycenter
    error code C47 for studio45
    i have tried 08-400 and reset it to 0 but it doesnt work, it will turn to 10 again after restart. Any other options i can do?
    • wtroll
      • May 2008
      • 85
      Hi,
      follow these instructions:
      [C47] IH power voltage is abnormal/IH initialization error
      1. Check the AC input voltage
      Check if the AC input voltage is within the specified range.
      (especially when the heater becomes ON after the power is turned ON (the copier is warming up))
      2. Check the thermostat
      Check if the thermostat is blown.
      3. Check the IH control board
      (1) Check if the AC input connector on the IH control board or the LGC I/F connector J522 is
      disconnected?
      (2) Check if the fuse on the IH control board has blown.
      (3) Replace the IH control board.
      4. Check the LGC board
      (1) Check if the connector J317 is disconnected.
      (2) Check if the conductor pattern on the board is short- or open-circuited.
      (3) Replace the LGC board.
      5. Clear the status counter
      • The error occurred when the machine is in the ready state: "17"
      Good luck!
