es 207
  • CJD900
    • Nov 2009
    • 18
    es 207
    Can you create templates on this copier?? If so how?
  • jinxs
    • Feb 2010
    • 43
    sorry, not possible
    • CJD900
      • Nov 2009
      • 18
      Thanks, I didn't think so but we have a customer that is confident that he has seen it done before.
      • TTL
        • Dec 2008
        • 127
        you can create templates, but only for the network scan (smb/ftp/email), and for this the machine need have the optionals (NETWORK PRINTER KIT – GA-1190, SCANNER UPGRADE KIT – GA-1200 and Extended Keyboard
        GJ-1040).
        And the registration of the templates is in the TopAccess (by the ip address of the machine).
        • CJD900
          • Nov 2009
          • 18
          Ok, what if it has all these options and still under registration there's only an option to store fax numbers?
          • TTL
            • Dec 2008
            • 127
            the Ga-1200 is in the right place? when you click in the scan button in the copier the led of the scan button stay on?
            • CJD900
              • Nov 2009
              • 18
              Yes it's in the right place. When we changed the control, we did use the same scan enabler from the old controller do you think that might have something to do with it?
              • TTL
                • Dec 2008
                • 127
                what control do you change? the Ga1190?
                • CJD900
                  • Nov 2009
                  • 18
                  yes we changed the Ga-1190. It works now, we got a new Ga1190 and a new scan enabler. The first one we put in it came out of a 207 that only had print (don't know if that had anything to do with it), and the scan enabler was from the original controller. So we installed a new ga1190 and a new scan enabler and it works fine now.
                  • jim v
                    • May 2008
                    • 41
                    You are limited to 10 templates on this model.
