help Toshiba E452/452
  • xuanquanghh
    • Mar 2009
    • 23
    Toshiba E452 fimware after I update the HDD (update categories 0 and Section 1) finished off reboot no longer on the screen. So I do? Thank you very much. please help me.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    There is something missing in translation...
    When you reboot are you saying it did not come up to copy screen or did not come up to firmware screen?
    Did you do 08-690-2 and 08-947 after the update?
    • xuanquanghh
      • Mar 2009
      • 23
      after I finished, the screen update fimware not power up anymore. I do not understand why more
      • Mr Spock
        • Aug 2006
        • 2064
        If you did the update and it finished successfully (no error) and power off you need to hold 4 & 9 to reenter the firmware update screen.
        If you did the firmware update then power up with 0 & 8 held down and do the 947 start followed by 690 2 start. This will format the harddrive so that you can use it correctly.
        If this does not work then you have one of three issues. The first is the firmware you have is not the one for that machine. The second is the firmware you have is corrupted. The last is that either the hard drive or system pwb is bad.
