Toshiba 3511 C020 Code
  • gitana1983
    • Mar 2009
    • 141
    Hello.... happy friday to everyone....
    I have a Toshiba E Studio 3511 with error code C020. The developer seems to be rotating normally and everything seems normal in general..... any idea about another thing that may cause this error?
    Where else to look? any reset?
  • ivovb
    • 695
    Seems is not enough. Pull out black developer unit and check if it is rotating by hand easily.
    Generally for this problem procedure is as follows:
    [C020] Developer motor abnormality
    Is the developer unit motor working? (Perform the output check: 03-112/162)
    NO 1. Check if the connector J578 of the developer motor is disconnected.
    2. Check if the connector CN348 on the LGC board is disconnected.
    3. Check if the connector pins are disconnected or the harnesses are open
    circuited.
    4. Check if the conductor patterns on the developer motor board and LGC board
    are short circuited or open circuited.
    5. Replace the developer motor.
    6. Replace the LGC board.
    YES
    1. Check if the PLL lock signal CN348-B6 pin output from the LGC board is always level “L”.
    2. Check if the voltage supplied to the ASIC input terminal IC38-150 pin is always “L”.
    3. Replace the LGC board.
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • tinnyjay
      • Oct 2009
      • 666
      circuited.
      YES
      BR
      Your anwser is up here Gitana1983!
      "Who loves the roses,must also bear thumbs"
