Can you set an E520 to copy to tray #2 on the MJ1027 ?
  • excanonguy
    • Jun 2008
    • 173
    I was trying to test this finisher thats interm. giving codes for the tray 2 bin lift, I wanted to set it so that I could run a copy job to tray 2 on the finisher, and I cant find any 08 code or user code to do so is it even possible? Never run into this on a Canon or Konica-Minolta machine.....
  • fireater
    Repair God? not quite
    • Apr 2006
    • 253
    not that i know of.... whats the code? i have had lift motors fail
    I fix copiers ...Well Sorta
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      I think you can do it through the web interface copier defaults under admin.
      • jonezy999
        just one copy??
        • Feb 2010
        • 952
        also could be harness.
        I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
        • ToshibaTech
          • Apr 2007
          • 580
          If it's not in the web interface or you don't find the 08 code ... You might be able to select the output tray in one of the tabs on the print driver. I know on some models you can, I can't remember if this is one of them or not.
          I will not give you service manuals or firmware.
          • Mr Spock
            • Aug 2006
            • 2064
            That is for the print jobs, he was looking for the copy jobs and I thought there was an 08 code but I can not find it. I believe that it can be changed under the copier defaults via webpage then admin and then copier defaults. but this is a "permanent" fix as it stays until someone else does it.
            • excanonguy
              • Jun 2008
              • 173
              Thanks for the replies guys ! Its a CB30 code , but it only does it when you are printing which of coarse uses tray #2 and it doesnt do it all the time. I wanted to be able to test it without having to constantly bother the secretary by sending print jobs lol . Since it is an intermittent code I am going back today and will replace the the tray #2 lift motor and see if the code goes away.
              • bauer
                • 72
                Have you tried going into Printer Folder >printer properties> printing preference>Paper Handling- CHOOSE TRAY> click Apply
                • Lepricon
                  ... Its a CB30 code..... Since it is an intermittent code I am going back today and will replace the the tray #2 lift motor and see if the code goes away.
                  If it is intermittent check and/or change the harness (cable tray) -99% accurate.
                  • Tokyo-Shibaru
                    also check the black plastic lever under the tray if seating in the right position and activating the sensor...if lift motor didn't fix the problem (most of the time is).
                    • Oystercopy
                      • Oct 2009
                      • 623
                      This is a bad Tray Motor, seen it quite a few times. I don't think there's a way to designate printing to one tray only, but I certainly could be wrong. OC
                      • ivovb
                        • 695
                        I am catching last sentence. Is there the same problem during initialization of the machine and finisher. If Yes check flaper's activity - does it moves up and down during initialization?
                        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
