'estudio 310c' error code C7
  • m_shamah
    • 14
    i have 'estudio 310c' give c7 .. i disconnect the feeder . but still give c7 ... any one know how to solve this for emergency ..or any program code to solve it ... and i need the service hand book for this machin . if any one have the manual .. i will be greatfull .thanks for all
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    I do not have a 310c book but the I have the 311c which has 3 c7* codes.
    [C72] Aligning sensor automatic adjustment error
    1. Check if any foreign matter is present between the aligning sensor and the reflecting mirror,
    and if the reflecting mirror is stained.
    2. Check if the harness between the aligning sensor and the RADF PC board is open-circuited.
    3. Check if any conductor pattern on the RADF PC board is open- or short-circuited mainly
    around IC1, IC14 and CN14.
    4. Replace the aligning sensor.
    5. Replace the RADF PC board.
    6. Initialize the RADF's EEPROM and perform the sensor automatic adjustment.
    [C73] EEPROM initializing error
    1. Check if any conductor pattern on the RADF PC board is open- or short-circuited mainly
    around IC7.
    2. Replace the RADF PC board.
    3. Initialize the RADF's EEPROM and perform the sensor automatic adjustment.
    [C74] Paper exit sensor automatic adjustment error
    . Check if any foreign matter is present between the exit sensor and the reflecting mirror, and
    2. Check if the harness between the exit sensor and the RADF PC board is open-circuited.
    around IC1, IC14 and CN8.
    4. Replace the exit sensor.
    • m_shamah
      • 14
      thank you mr Spock . but i still junior , i try to solve by these steps.. no change ..is there mor solutions ..can you send me book of 311c please ...tahnk you very very very much
      • Mr Spock
        • Aug 2006
        • 2064
        Did you replace the adf pwb then initialize the eprom? If so then check the harness from the adf to the scanner (slg) pwb in the optics area.
        • craig
          service manager
          • May 2010
          • 23
          on the early toshiba's a c7 error was a fuser error. You might try there.
          • Mr Spock
            • Aug 2006
            • 2064
            The 310c and the fc-22 book has the same error codes as the 311c book. Are you sure that is the only 2 digits of the code or that 310c is the fight model?
            • ss12
              • Jul 2008
              • 289
              just checked the 310c handbook,c7 is afuser related error.check the usual suspects,thermistors therrmofuse& lamps before 08-700 fuser reset
              • m_shamah
                • 14
                yes Mr spok . it is too digit... c7>>>>>i will try to reset 08-700 and seee..
                but i did not have handbook if any 1 had .310 or fc22.. or 311c...please share
                • ivovb
                  • 695
                  [C7] Error C7
                  *To avoid any hazards, be sure to unplug the power cord before proceeding to check the items
                  in 1. and 2. below.
                  * Be sure that the fuser unit is set in place securely.
                  1. Check if any thermistor connector is disconnected.
                  2. Check if any harness of the thermistors (center/rear, upper/lower) is open-circuited.
                  3. Check the LGC board if the connector J122 is disconnected.
                  4. After completing the repair of what caused the [C7] problem, proceed to rewrite the status
                  counter (08-700) to "0", following the same procedure as for [C41] to [C48] .
                  This is from C310 HB
                  BR
                  I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
                  • Mr Spock
                    • Aug 2006
                    • 2064
                    I rechecked and that is in the book but not in the list of error codes at the front. And is as Ivovb has posted.
                    • jamesyboy
                      toner monkey
                      • Jul 2010
                      • 188
                      I think you will find C7 is a fuser lock out code 08-400 set to 0 clears code
                      [C7] Error C7
                      in 1. and 2. below.
                      counter (08-700) to "0", following the same procedure as for [C41] to [C48] . If you need a manual contact me and I will email you one cheers Jamesyboy
