toshiba e-studio45 wont power on!!
  • downhiller67
    • May 2010
    • 67
    good day!
    sometimes i need to power off the copier for a couple of minutes for some reasons, but when im going to switch it back, it wont power on, it would take at least an hour before the copier powers on.
    could somebody please help me on what maybe the problem on this machine.
    thank you and more power!
  • Harry
    • 228
    this is maybe a powersupply problem, try to change the kondensators ore change ps if you have one.
    good luck
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
      Paul@justmanuals.com
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        Check the following (no specific order)
        hard drive
        fuser thermistors
        door interlocks
        main power switch
        power supply.
        • tech07
          • Aug 2008
          • 410
          I,ve seen this quite a few times. Most of the time it's the power supply and have had 1 or 2 sys boards fail. But power supply unit mostly
          • downhiller67
            • May 2010
            • 67
            thank you for the replies, going to check it out, i've already changes the fuser and the hard drive. maybe the power supply, interlocks.
            more power.
            • ivovb
              • 695
              Voting for power supply. My statistics - 99%.
              BR
              I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
              • tinnyjay
                • Oct 2009
                • 663
                BR
                I think you must do like this downhiller67
                "Who loves the roses,must also bear thumbs"
                • jamesyboy
                  toner monkey
                  • Jul 2010
                  • 188
                  This machine has a swichable power supply a toshiba trate, they have to discharge before they recover a problem on early models power supply can be modified by changing a diode cant remember which one long time ago change the power supply best fix
                  • esam ramadan
                    • 199
                    Re: toshiba e-studio45 wont power on!!
                    what the capacitor number or are there an image show it cause i have 5 powersupplies have this problem thanks
                    • rose
                      • May 2012
                      • 1
                      Originally posted by downhiller67
                      good day!
                      You try change all photo couplers in power supply unit.
                      • esam ramadan
                        • 199
                        are there any help just i want to know the part in the board that make the problem and wish it with image
                        • esam ramadan
                          • 199
                          i got it just resoldering these parts and it will work good - it is not capacitors problem
