toshiba estudio 160
  • Thomas Wendt
    • Jul 2025
    toshiba estudio 160
    I have a toshiba e-studio 160 series, with ethernet card. As i have to change tcp/ip options, i need to know the password!!! (please, don't ask why i dont' know it :_| ) I read somewhere that should be possible to show the admin password by: 1 - powering the machine in TEST MODE (pressing 0&8 while powering) 2 - typing 263 and pressing START Point 1 it's ok, but point 2 doesnt' return any information. Maybe the page where i read this trick was for another model, different than e-studio 160, and so i have to type another number.. its not 12345 or 123456 I hope that someone could help me thanks Benny
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    08-263 is for the ebridge series machines and this is well before that.
    to change ip
    program
    initial setup
    network
    then scroll to the settings that need to be changed
    should not need a code unless someone turned on department codes
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
      Paul@justmanuals.com
      • ivovb
        • 695
        Thomas, You are trying to change ip address via network interface. Don't. Do it Mr Spock's way.
        BR
        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
        • Thomas Wendt
          master-password or reset all
          My problem is not the change of the IP address and integration on the network, I have done this over the keyboard and the settings. Unfortunately, I cannot print with the device and not change the remaining settings about http: //, because password is not known, ping ist ok!
          • ivovb
            • 695
            So there is a department code. Is it? Can You make a copy?
            BR
            • Thomas Wendt
              remaining settings
              Unit Serial No: 143530 Network Address: 00:80:91:22:30:aa Novell Network Information Network Topology: Ethernet Network Speed: 100 Megabits TCP/IP Network Information Frame Type: Ethernet II Subnet Mask: 255.255.255.0 DNS Address: 10.52.115.1 WINS Name: Not Registered - MFP_143530 IPP Network Information Internet Printing Protocol AppleTalk Network Information Frame Type: 802.2 SNAP On 802.3 Protocol Address: Net Number 65384 Preferred AppleTalk Zone: Preferred AppleTalk Type: Version: 06.19 TA disabled Connector: RJ45 enabled Protocol Address: 192.168.2.209 Default Gateway: 192.168.2.1 enabled http://192.168.2.209:631/Print enabled Node Number 224 Socket Number 129 Default Zone LaserWriter Novell inactive Peer-to-Peer Connection Information Printer Name: MFP_143530 AppleTalk Connection Information AppleTalk Printer Name: MFP_143530 TCP/IP Connection Information Port Number : 10001 OK? Thomas
              • Harry
                • 228
                Check your Private message
                Ciao Harry
