Toshiba estudio 35 F10
  • Naveed Shahid
    • May 2008
    • 162
    Hello Every One
    I am facing a problem F10 In toshiba 35 copier
    thanks
  • jamesyboy
    toner monkey
    • Jul 2010
    • 188
    f10 is hard drive error
    its an old machine small hdd try formating hdd 08-690
    you may need to replace hdd standard hdd jumper positions set as master
    • Naveed Shahid
      • May 2008
      • 162
      i installed a new hdd but facing a problem diffrent machine hang and displat wait warming up
      i am try to format 08-690 but error display can u give me a producer when install new hard drive
      thanks
      • ToshibaTech
        • Apr 2007
        • 580
        Take inner cover off, take a metal plate off, unplug a bunch of plugs from the top board, remove top board, unplug/remove HDD. Replace HDD and reverse steps and do 08-690 again.
        I will not give you service manuals or firmware.
        • ivovb
          • 695
          thanks
          Check thermistors in fuser unit.
          BR
          I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
          • Naveed Shahid
            • May 2008
            • 162
            i try 08 690 and he display error and machine hang
            • ToshibaTech
              • Apr 2007
              • 580
              Try swapping out the HDD with another IDE HDD. Capacity shouldn't really be a factor.
              My previous post: "Take inner cover off, take a metal plate off, unplug a bunch of plugs from the top board, remove top board, unplug/remove HDD. Replace HDD and reverse steps and do 08-690 again."
              • Naveed Shahid
                • May 2008
                • 162
                sir
                my question is if i install one new hdd drive on machine need to update firmware or not
                what is the producer of when i installl new hard drive
                thanks for u support
                i am waiting ur answer
                thanks
                • ivovb
                  • 695
                  sir
                  thanks
                  You do not need firmware when replacing HDD. Do as ToshibaTech says. Just check HDD's jumper settings!
                  Concerning HDD capacity. I am sure that 10, 20, 30 and 40 Gb will work. I have tested unsuccessfully 80 Gb with 32Gb limit.
                  BR
                  • Naveed Shahid
                    • May 2008
                    • 162
                    Thanks sir do give me a helpfull information now i finish my job
                    thanks once again
                    thanks
                    • ToshibaTech
                      • Apr 2007
                      • 580
                      BR
                      .... interesting the 80GB didn't work? When I tried to order one the other day it pointed the many times updated but still old 80GB number to the new 160GB drive toshiba is using for the EB1, 2, 3 machines with IDE drives. I wonder how they are supposed to work.
                      • ivovb
                        • 695
                        Yes It seems strange. As I see there is a BSI from 26.07.2010 that 40Gb is discontinued and 80Gb is available. That 32Gb limit must be the culprit. I haven't test it as 80Gb...
                        BR
