eS-200L and 550 hard drive wipe
  • Toner Boy
    • Aug 2007
    • 365
    We are trying to upgrade this customer but the drives need to be clean before the equipment goes back to the leasing company. As for the 550, I know we can format the big drive (copy data) which should clean it (??) but don't know if image data is stored in the controller HDD as well. I don't know if the 200L has one or two drives and am clueless as to how to clean it/them. Anyone been through this before?
  • emujo
    • Jun 2009
    • 3009
    The leasing company doesn't care, so the request must be coming from the customer..08 690 will format the drive... this will remove any stored addresses, secure print jobs, and delete any files stored in the mailboxes. But, some of the data on the drive would still be recoverable by a professional hacker...put a new HDD in the MFP, and bill the customer 300-350 for the time, give them the orignal HDD and everyone should be happy. The E550 has an internal HDD, and also 1 in the GL 1020. Emujo
    • Toner Boy
      • Aug 2007
      • 365
      Thanks. The GL-1020 drive is of concern to me since it may need to be operational and I think we need system software to make it work? Is this the same scenario for the drive in the 200L? I am assuming that machine only has one drive, and machine will still work after just replacing and formatting the drive?
      I have a source for the HDD (550) but not the GL-1020 drive. Nor for the 200L. Any resources I might check?
      • emujo
        • Jun 2009
        • 3009
        E202L Needs format and firmware reload after drive replacement
        E550 MFP drive replace and 08/690
        GL1020- Needs OS partition and OS recovery to function
        PM me if you want to obtain any of the software/firmware. Emujo
        • JustManuals
          • Jan 2006
          • 9838
          I've got all the GL-1020 software.
