eSTUDIO 650 Error Code C37
  • mitsubee
    • 176
    Hi guyz ,
    my office estudio e650 suddenly appear error C37 , from the services manual it says Transfer Belt Motor abnormal , anyone here could please help..Thanks
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Either the logic pwb rapped out or the cam on the back of the machine that lifts the transfer belt is not working correctly.
    • tinnyjay
      • Oct 2009
      • 666
      Originally posted by mitsubee
      Hi guyz ,
      You have SM and you know what this code means!
      Why you dont remove Transfer Belt to check and clean it,contacts,wires etc.
      Use a multimeter to check if belt motor is working or not.
      If it works,it means you can have problems with wires,conntacts and LGC board.
      Ones i had that problem,it was problem of LGC board.
      Just study!
      "Who loves the roses,must also bear thumbs"
      • ivovb
        • 695
        I am voting for cam - it breaks some times.
        BR
        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
        • Mikey
          • Sep 2009
          • 54
          You're lucky to have a manual. Can you share that to me? Pls send it to my email: mixigould@yahoo.com. BTW, remove the motor, turn the shaft and feel the smoothness of turn. Check also the connection of motor maybe it's not tightly connected. Use your ohmeter to check the continuity of the wires. Check for any cold solder on the board. I hope this helps. Goodluck.
          • Mikey
            • Sep 2009
            • 54
            I don't have service manual. However you may try this; Press and hold 0 and 3 while turning on the power. Enter code 114. This will make the Transfer belt motor run. Press Clear/Stop to end the test. I would appreciate if you will share the service manual with me. Kindly send a copy to my email address: mixigould@yahoo.com. Thanks.
