Toshiba eStudio 3510c HDD reformat
    • 23006
    [Misc] Toshiba eStudio 3510c HDD reformat
    So I was asked today to wipe the hard drive on a Toshiba eStudio 3510c. Not being a Toshiba trained tech, I'm not sure exactly what's involved.
    I know some MFPs hold firmware/system software on the hard drive. I don't want to turn the machine into a doorstop. I just want the documents purged that are stored on the HDD, and have a functioning MFP left. It's OK if the network/scanning setup information is lost. It's getting returned to the leasing company.
    I don't mind selling them a HDD if that's required, but what about firmware/system software/settings? What do I have to do? =^..^=
  • jamesyboy
    toner monkey
    • Jul 2010
    • 188
    two ways you can clear scans etc on a tosh via top access delete all logs
    or format hdd )o8-690 this will not effect any firmware only remove scans etc on hdd any user codes or templates etc
    if they want to keep their hdd a stnd hdd is all you need set to cable select put it on the machine and format 08-690
    sorted
      • 23006
      Originally posted by jamesyboy
      ...if they want to keep their hdd a stnd hdd is all you need set to cable select put it on the machine and format 08-690
      sorted
      Please explain "set to cable select".
      • jamesyboy
        toner monkey
        • Jul 2010
        • 188
        cable select ce enabled this is baically the hdd setting
        you will see a label on the hdd match jumper setting to ce enabled they mostly come like this but if its wrong say set as master the hdd will not work on a tosh box
          • 23006
          Thanks. =^..^=
          • JustManuals
            • Jan 2006
            • 9838
            Dave- If you want the Parts & Service manual I'll send it along at no charge. I 'may' be able to get you the firmware as well. Let me know.
            Paul
              • 23006
              I'll let you know if I get the job. =^..^=
              • Mr Spock
                Vulcan Inventor of Death
                • Aug 2006
                • 2064
                If you replace the drive you will need to reload the firmware. If you have the firmware then there is a quick option to remove and replace the partition (needs to be done on a replacement anyway).
                If you need anything pm me and I will see what I can get to you. By the way the most recent firmware for this machine is 120megs.
