Option to print color - Unavailable?
  • Norma_D
    • Sep 2009
    • 10
    I'm trying to print in color on a Toshiba E-Studio 451C from my computer but its not giving me the option. I'm not having the problem with printing in Black/White, not sure what else to do at this point. Any help would be great!
    Norma
    • 23010
    Is it possible that your administrator has blocked you from using color when printing? =^..^=
    • Norma_D
      • Sep 2009
      • 10
      I am the administrator.
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        Which driver? Are there department codes in use on the copier? Did it work before and not now or has it always been like this? You can setup a code for color and set it to unlimited black and it may not pop up and ask for the code but delete the color job and allow the b/w to go through.
        • Doctor
          • Sep 2010
          • 133
          Norma
          Are u sure u're using the right driver? Drivers for B/W printers like 282 and 352 will also print to 451c bbut only B/W.
          • Travis06
            Tech.
            • 193
            I remember running into this a few years ago, There is a difference between the PCL and PS driver. One won't print in color. Can't remember which one won't.
            • ToshibaTech
              • Apr 2007
              • 580
              You need to use PCL5c or the PS driver on this machine. PCL6 only gives the option for B/W. Hope this Helps!
              I will not give you service manuals or firmware.
